Originally posted by: Fox5
For instance, say my car is 1500 pounds, and has 142 horsepower, what exactly does that mean? Can the horsepower be used to determine the maximum speed, or what?
Sort of. But you can't just rev an engine higher and higher and keep getting more and more horsepower. Other factors come into play, like how much the heads can flow.Originally posted by: infestedgh0st
Originally posted by: Pacfanweb
Wrong. Once again, HP and Torque are NOT mutually exclusive. Gearing and weight matters to every single vehicle made.Originally posted by: infestedgh0st
Originally posted by: ElFenix
horsepower is nothing more than torque at a high rpm. it means you don't have to shift as much.
the manufacturers put emphasis on hp because power figures aren't changed by the lever action of a transmission, while torque, as a type of force, is. so, each time you change gears your torque at the wheels is changing, but your horsepower isn't. which is why you accelerate harder in first gear than any other.
actually, hp = torque x rpm / 5252, which means when u rev ur engine hp does change.
hp + gearing matters more on a racecar. Torque makes everything run; excessive torque makes everythign smooth.
You can't have HP without torque.
obviously, the equation shows that they are NOT mutually exlusive. If torque = 0 then u can't have hp. hp is the measurement of how much work can be done with the torque from the engine at this rpm. Basically the higher you rev, the more hp u get. Torque however has its own torque curve.
Originally posted by: 91TTZ
Good post, pac.
That's why it annoys me when I hear a racerboy with no knowledge of engines say crap like, "yeah, the LS7 makes 500 hp but it needs 7 liters to do it! Hondas engines can rev to 9000 rpm!". Like you said, having to rev high is only a means to an end, it isn't the end, HP and a nice torque curve is.
Originally posted by: JoLLyRoGer
Now, it's important to understand that nobody on the planet ever actually measures horsepower from a running engine. What we actually measure (on a dynomometer) is torque, expressed in foot pounds (in the U.S.), and then we *calculate* actual horsepower by converting the twisting force of torque into the work units of horsepower. [/L]
That is incorrect.
I had a long discussion about this on another forum, and emailed Dynojet Research to confirm it. A Dynojet directly measures horsepower, and back-calculates torque.
The reason lies in the way that dynos work. An inertial dynamometer knows the weight of the drum, and the time it took to accelerate it up to a certain speed. With that data, they can calculate the amount of *power* that the drum stored during the run. With the tach connection, they get the RPM data, and with that they can back-calculate the torque.
If you've ever had your car dyno'd and the tach pickup isn't working right, the dyno will still know the horsepower produced, but it will not know the torque, since the element of rpm isn't known. But since the dyno directly measures horsepower, it will still give you your HP output.
Originally posted by: Injury
So, in layman's terms, would you guys say that horsepower is a measurement of the force at which a car is propelled foward?
And if horsepower is a constant, then the scope of its power is directly related the weight it must push?
Does a car deliver the same horsepower no matter how far in a person pushes the gas pedal?
yeah yeah, I'm a bit of a car n00b, but cars are one of the things I'd love to know much much more about than what gran turismo can teach![]()
Again, it just depends on what application you want to put the engine to work in. But more torque is always desireable. If race cars like Nascar or F1 could build engines that has so much torque that they only needed to turn 4000 rpms to move the cars as fast as they needed to go, they would. But that is impossible, so they build/gear them to suit their particular needs, based on the limitations of their respective rules.
actually, f1 engines are limited to 3 litres with 10 cylinders. There isn't that much torque that could be produced by a 3 litre. The only reason why it moves quickly at even low revs is because of its light weight. The reason why they can accelerate so fast and have such stable power for cornering is because of the smooth torque curve, percise gearing, and the ear-breaking 18,000 rpm redline.
with even 250 ft/lbs of torque at 18,000 rpm, you can generate 856 bhp at the redline.
of course when your building a luxary car (such as the rolls royce), you would want to have a massive engine that produces a lot of torque at relatively low rpm, since most people wouldn't want to shift and rev as much just to "go fast" on those cars.
But always remember that the more displacement you have, the bigger your engine will be, and the heavier it will be.
You pretty much just said the same thing he just said.
read the last sentence. and what he said was also what i said earlier.
Actually, weight has very little effect on top speed. Aerodynamics are several orders of magnitude more important to overall top speed. Conversely, aerodynamics have little play in acceleration (up to about 85 mph) while weight plays a very large factor in acceleration.Originally posted by: everman
Torque and aerodynamics are also important factors, not to mention hauling around sumo wrestlers which will also kill top speed and acceleration.
Originally posted by: QuitBanningMe
WTF car do you have that is 1500 ponds?
I have a "light" car and it is 2600 pounds.
Horsepower is the amount of raw power output times the power of a single horse.
1HP = the power of 1 horse.
500HP = a lot of horses.
This is why a car with a torque curve that falls off quickly (IE: engine can't breathe well at higher RPM's) isn't as much fun to drive and isn't as fast as as car that does have the torque up high.
seriously, you have no clue wtf you're talking about.Originally posted by: IHateMyJob2004
You are a retarded. Sorry about name calling rules, but this most accurately descirbes this post.
Google is your friend.Originally posted by: Injury
No, HP is a measurement derived from torque, which is basically what you described.
No, the power is the same, the weight determines how quick/fast you can go with that amount of HP. So do other factors, like traction and aerodynamics. Most passenger cars would not be able, if they didn't have rev limiters, to reach max. rpm in high gear...the wind resistance would be too great for their engines to turn up in high gear.
No. Max HP is only obtained at WOT. (wide open throttle)
