TanisHalfElven
- Jun 29, 2001
- 3,512
- 0
- 76
It all depends in screen size. The pixels in a 24" 1920x1200 LCD are the exact same size as those on a 19" 1280x1024 LCD or a 21" 1600x1200 CRT, so the possibility of seeing jaggies is still there. Now, if you run 1600x1200 on a 15" CRT then I guess I could see what you mean.[/quote]Originally posted by: nitromullet
Can't play games without AA... Just can't do it... I try, but I can't. Then again, I really don't like low resolution textures either. Some shadow effects that have a very high performance hit aren't even all that great, and these can certainly be sacrificed... Soft shadows in FEAR are an example of this. You really have to weigh it out on a game-to-game basis what eye candy can be sacrificed if necessary.
q]Originally posted by: Regs
Jaggies? What is this, 2001?
I haven't seen jaggies in a long time at 1600x1200. I'd take HQ over any filtering anyday.
Originally posted by: s1rwilliam
why not low quality with 16xq aa
That's incorrect. You may be thinking of the 22" LCDs at 1680x1050, but the 24" have a .270mm pixel pitch compared to the 19" @ .290-.300mm or so. Only panel that has higher pixel pitch I believe are the 27" 1920x1200s, with the 20" 1600 and 30" 2560 with the lowest. Its almost the same vertical height but the 24" have the extra 176 lines of vertical resolution.
Edit: Just re-read and saw you stated pixel size. Might be right on that, but I'll have to double check. Eye-balling it on my 24" Gateway and my 19" Dell though, that doesn't seem to be the case either.
Originally posted by: CP5670
I like smooth motion more than anything else, so I often turn down both to get good framerates.In general though, I would take the game's graphical options over any AA, except for some effects that cut down on the performance a lot (shadows are a common culprit here).
