Originally posted by: Topplayer
dl wow from bliz
Originally posted by: AnonymouseUser
Check your BIOS settings and make sure you have the correct SATA settings. IIRC, having SATA II settings enabled for SATA I drives causes issues.
hmm this sounds like i should look into it, what would those settings be called? The mobo has 8 built in sata II ports: 4 NVraid, 4Silicon, they are both default sata II, but when i have a sata II raid set up, ill have to mix them with the raptor in order to be on one raid....(if what you say is the case, ill have to enable sata I and II at the same time to use the particular raid 0 i need)
Actually, just did some quick research, and it isn't a BIOS option but a jumper on the HDD which forces SATA 150. Worth a shot at this point.
Originally posted by: Aikouka
I've heard about the 2nd WoW CD messing up for quite a number of people, it's your CD, not your computer. Just copy the contents of your all 4 (or 5) CDs to the hard drive in reverse order (this ensures you don't have to go back to CD 1 and copy the install.exe off of it). You can burn a DVD with this if you'd like an optical copy.
I'm a bit curious, load the 2nd disc via software (i.e. mount an image) and physically try the third disc. I'm wondering if you'll see the same result for the 3rd disc since the first disc works for some reason.
If you're curious about your PSU, check your voltages while accessing the raptor drive (it shouldn't have to be while installing either, but during something fairly intensive).
Is your mobo flashed to the newest BIOS?
