VinDSL
Originally posted by: bsobel
Did you run chkdsk /R or just chkdsk?
Er...
You mean chkdsk /F /R right?
Originally posted by: VinDSL
Okay, I'll bite...
Where can I find this software you wrote, and how much do you charge to recover data from HDs?
Er...
You mean chkdsk /F /R right?![]()
You first. I asked what your qualifications where. Are you going to answer?
I suggest you salvage YOUR reputation first...![]()
Originally posted by: dbarton
I ran chkdsk from the right click menu of my computer, and did check the surface scan and fix problems boxes. Hard to tell if the problem is solved as it only seemsed to fail now and again, and maybe most often when doing a backuup, so large amount of data are being copied.
That's the equivalent of doing a CHKDSK /R from the command line.Originally posted by: dbarton
WARNING! F parameter not specified.
Running CHKDSK in read-only mode.
CHKDSK is verifying files (stage 1 of 3)...
File verification completed.
CHKDSK is verifying indexes (stage 2 of 3)...
Index verification completed.
CHKDSK is verifying security descriptors (stage 3 of 3)...
Security descriptor verification completed.
Windows has checked the file system and found no problems.
293824408 KB total disk space.
280887800 KB in 88951 files.
57824 KB in 5315 indexes.
20 KB in bad sectors.
181628 KB in use by the system.
65536 KB occupied by the log file.
12697136 KB available on disk.
4096 bytes in each allocation unit.
73456102 total allocation units on disk.
3174284 allocation units available on disk.
F:\>
(Then again, maybe its your power cable)
You might have a flaky Y-connector on your power supply cable to the driveor whatever.
I'm suspecting it's something other than a HD failure, however, I would make sure you're backed-up, just in case!
That's what I was waiting for...
'/F' aside, this proves your HD is dieing!
Do an extended write, and pull the power connector to the drive in mid-action.
I would swap the drive.
Thank you!![]()
chkdsk /r
LoL! I'm NOT trolling!
This isn't a laughing matter any more, Bill!
You know the guy's HD is going bad, and so do I...
Why lead him on?
