AntisociaL
Have you tried to use it? I had an xp with a broken off pin that still ran fine.Of course it may also burn up the rest of your stuff 🙂
$219.00 cheap? Worth more than any cat!Originally posted by: aircooled
if you can't solder it back on, just buy a new one at newegg. they're cheap
wouldn't deadless imply "not dead"
Originally posted by: Yossarian
if you're lucky it's just the pin for a number you don't use often, like 8. don't try to type '8' too often and your computer should be fine.
Originally posted by: Pepsi90919
PIN
MIKE
Originally posted by: FoBoT
so is it dead or undead?
why are you claiming to have a zombie CPU ?
Originally posted by: Mo0o
Wtf is deadless
I hope you're joking..
indeed, I used to be a field engineer for Unisys(top tier Dell field support provider), we don't give a crap how things got broken, as long as we make our calls for the day. As far as we are concerned the idiot dell tech support people told you take your processor out and you where too stupid to put it back in correctly.Originally posted by: ToeStub
Originally posted by: FleshLight
Removing hsf = void dell warranty.
BS
