swimscubasteve
- Jun 10, 2005
- 523
- 0
- 0
Originally posted by: spidey07
Originally posted by: swimscubasteve
Not exactly. You need to dry your wood next to the fire. And if it is only covered with snow it won't be too wet. It also help to burn smaller sized wood and not try and ignite logs.
Meh, if the fire is hot enough it doesn't matter. But your right. The snow will insulate the wood and it should be pretty dry, sript the bark if you need to. Having a big arse fire sure doesn't hurt in drying out that wood though. If anything strip the bark, put that close to the fire and use it when you need a boost. I'm not saying pile on huge fuel logs. Just build a really big/hot bonfire, get the heat up and then burn your wet stuff. Heck even a campfire can light up wet evergreen branches.
-edit-
Kim's demise was mainly due to not building a roaring, huge, fire.
well said. sounds like you wouldn't have died out there.
