what cookies should I bake tomorrow?
nageov3t
42,808
83
I fail for not including a poll :(
if I were going to bake something I've already baked before, I'd make my greatest cookies ever, chocolate w/ whiskey-marinated cherries.
shopbruin
5,817
I just bought these:
http://www.williams-sonoma.com/prod...4|1||4|star+wars+cookie+cutters||0&cm_src=SCH
So I will be making these cookies this weekend.
Last weekend, I made a batch of Soft and Chew Chocolate Chip Cookies from Martha Stewart
KeithTalent
Administrator
Nov 30, 2005
50,231
118
The Macadamia Nut is hands down the most overrated nut ever, I would never ruin a cookie with them.
Make snickerdoodles. I love snickerdoodles when they are done well.
KT
shopbruin
5,817
KT
BLASPHEMY!
Here are my snickerdoodles:
My white chocolate macadamia:
Unfortunately, this picture isn't very good, which just means I need to bake them again, but I've been too cheap to buy macadamia nuts. And this batch is overbaked. But I love white chocolate macadamia cookies...
KeithTalent
Administrator
Nov 30, 2005
50,231
118
Those are some beautiful doodles! :awe:
Macadiamas have no flavour (they really just taste like fat), the only thing they add to a cookie is texture and you can get the same texture, with actual flavour that will enhance the cookie, from other nuts.
KT
Locut0s
22,205
44
KT
snickerdoodles? Why does that sound like a euphemism for dog droppings?
nageov3t
42,808
83
ended up making double chocolate (melted semi-sweet in the dough + dark chocolate chips) sea salt cookies.
omfg they're good... they might be my new best cookies, throwing my whiskey-marinated cherry cookies off the throne.
Crono
23,720
1,502
KT
Macadamias have flavor, it's just subtle. Which is what you want in a cookie, not overpowering crunchiness or nuttiness. It really complements the smooth taste of white chocolate and is incorporated well into the soft chewiness of a good cookie.
You have to use good quality, unsalted macadamias. Very delicious raw, as well.
Mike Gayner
6,175
This thread motivated me to make white chocolate & macadamia cookies. Currently in the oven. Won't be able to photograph as my camera is kaput.
Crono
23,720
1,502
As the official spokesman for white chocolate, I am obliged to tell you to enjoy your magically delicious cookies :)
Mike Gayner
6,175
Enjoy!
Why is your camera kaput? :( Hope you just mean the battery.
Yeah the battery is buggered.
The cookies are finished, and they were pretty good. Every cookie I've ever baked has burned on the bottom though - they'll be just right or slightly underdone on top, but the bottom is already dark and crispy. IDK how to solve this.
shopbruin
5,817
What type of cookie sheet are you using?
Your cookie sheet ideally needs to be lighter in color. I had a darker baking sheet once and it killed the bottoms of my cookies, because it absorbed more heat and overcooked the bottoms.
Next, check the temp of your oven. Get an oven thermometer. Your oven might be hotter in some regions, although if all your cookies are dark on the bottom this might be it. If you discover your oven has hot spots, just rotate your cookies halfway during baking. If you bake two sheets at a time, turn the sheets around halfway through, AND rotate the sheets from rack to rack.
Is your oven electric or gas? Make sure the cookie sheet is on the middle rack.
Another trick: When you remove the cookies from the oven, let it sit on the cookie sheet for 2-3 mins, and then remove the cookies to a rack to cool. Let the cookie sheet cool down before you put more batter on it. This way you can remove it before it gets too done, as it still bakes a bit as it sits on the sheet. Cookies are done when they brown around the edges.
I only bake (now) using parchment paper. Before, I used non stick aluminum foil. I have completely stopped dropping the dough directly onto the cookie sheet. Both ways, I don't have dark cookies and they don't stick to the cookie sheet. Plus it's so much easier to keep everything clean.
Mike Gayner
6,175
Thanks freesia39 - I want to try a new baking sheet. Currently I use a black painted steel sheet with parchment paper. I also want to try the same sheet but with a silicon mat instead of parchment paper.
Crono
23,720
1,502
I second everything freesia said. It's key to remove cookies before they look fully done. Same thing applies to biscuits or other baked goods using a conventional oven.
Locut0s
22,205
44
Not when you get to eat the result, lol.
Besides, men have been cooking stuff over fire for as long as women have. Perhaps even slightly longer.
And the fact that until recently just about all chefs were male.
nageov3t
42,808
83
switching to a shinier cookie sheet would help.
Dark-colored surfaces absorb more heat than light-colored surfaces (which reflect it), so more heat gets transferred to the food.
something like this is what you want.
