but eist and turbo enable....This says you have EIST disabled.
system 32 ...? which files???yep sttingns to 37 for core you can have this..but it is not working in real life
have you renamed windows32 dll?
work all core turbo x37 for you real...?upload hwinfo64 image...system 32 ...? which files???
...or can I use the Z10PE-D8 WS ModBios also for the D16, I guess not, right?!
i modified this...but nothing...can it be from microcode in system32, mcupdate modified or deleted?
I wonder if the problem is *no* microcode applied. Perhaps the system will not properly turbo without something applied. Have you tried applying a microcode at boot following UEFI programming?
Start here:
https://labs.vmware.com/flings/vmware-cpu-microcode-update-driver
Also...
New Broadwell-E/EP RC9 release build to set OC lock bit following programming. Please try this:
https://github.com/freecableguy/v3x4/releases/tag/v3x4-0.10b-i406f1-rc9
if you're using an ES1 chip that uses microcodes with a mask of 0x80000000, you almost certainly won't find it in the cpumcupdate dll unless you add it yourself. That should be able to be extracted from your BIOS if it has a 0x80000000 mc update, which it almost certainly does.i have cpumcupdate2.1 but i havent broadwell file for example: 0x27 - 0x38 -0x39 for hoswell...please help for this and i checking..
i test this v3x4-0.10b-i306f2-rc9_no_ucode_lock_oc.efi
all is wery well to programming and in hwinfo64 multiplier all core is x37 but when i stres test cpu-z or rendering cpu show x28 also normal without turbo all
just core 1 is x37 ...!
i dont no..help me for that ...?my chip is aptio vif you're using an ES1 chip that uses microcodes with a mask of 0x80000000, you almost certainly won't find it in the cpumcupdate dll unless you add it yourself. That should be able to be extracted from your BIOS if it has a 0x80000000 mc update, which it almost certainly does.
kjboughton dont be tired...
kjboughton in now time all is ok just one problem is cpumcupdate2.1 for broadwell and all turbo multiplier core show x37 in aida but in cpu-z ,hwinfo64,other win software(3dsoftware) all core turbo to x28)!!!
in aida all core x37 and stres cpu-z to x28..i also set bios to turbo charger...but i dont know >>(C 0,c1 ,c2 , c6 state cpu ??)
i also modified mcupdate file to cancel update microcode (mcupdate_GenuineIntel ,mcupdate_AuthenticAMD ,mcbuilder)
E5-2696 V3 may be vulnerable![]()
What should I post? More than willing to do this.Somebody post a couple of V4s to @kjboughton. He will find a way. That in my opinion would be the fastest method.![]()
