@GTZ no ratio overclocking for that CPU so this bug will not unlock the i5 -4460 unless perhaps one can write microcode. Best that you can probably hope for is all cores at 3.4GHz if set with a microcode version of 0x7 or less.
@fromax legacy mode should not matter, try running the shell driver in test mode first and from there exit to W7 or are you already able to do that? If it's a case that you are successfully booting W7 but stuck with base clock then please post a CPUZ txt report. First time I ever heard of RU is when The Stilt posted it so he may be able to give a few pointers. The MSR settings are already noted in the thread, V3.EFI was just meant as a crude way to apply those settings.
@vadimkara my microcode is not removed but modified similar to post #101. If it's not posting with default settings (no OC / FIVR defaults) then perhaps that CPU / BIOS combo relies on something being fixed from the microcode. Do note for that CPU it will be microcode with CPUID 306f1? not 306f2.
@Soarer while waiting you could go through the steps fromax took to modify his BIOS and possibly try something similar.
