Thanks!Here's the ones I have downloaded locally, both are the two versions that have circulated on this thread....
https://drive.google.com/open?id=0Bxc6PUFWfKMzYnBmT2JWeDZVeFk
https://drive.google.com/open?id=0Bxc6PUFWfKMzRU5acjFyYkJ3V1U
After you subtracted 4 there (changing 0C to 08), it's also important to step back 3 bytes and add 4 there. That way the checksum stays the same. It's the method suggested at Win-raid forums, I've used it numerous times for different people, it works fine!Then ran into the APTIO thing (error replacing file) trying the UBU method. I'm about to try the work-around now (find 2E06A0 + 14 bytes and change the 0x0c flag to 0x08).
Understood...After you subtracted 4 there (changing 0C to 08), it's also important to step back 3 bytes and add 4 there. That way the checksum stays the same. It's the method suggested at Win-raid forums, I've used it numerous times for different people, it works fine!
Trouble is the Z10PE-D16-WS is spitting out all attempts to use flashback to load bios images that report "failed integrity check" in the normal EZflash tool. That is, the one I edited and the 2 posted tonight all produce the same result:
1. plug into flashback port
2. press flashback button
3. 5 blinks
4. solid blue... (indicating it is NOT loading the flash as I understand it).
Why not? That way you would know if it's your USB stick that is the problem or something else.I've now successfully flashed an unedited 3305 and 3405 image tonight (though through ez-flash not flashback)...
Great!EDIT: Ok, it looks like it is a USB compatibility issue. I copied the UBU output (APITO work-around + UBU) to a new USB drive and it appears to be working. Just a normal fat32 4G drive (that isn't working)...
Hangs hard at the same spot (setting host-name) every time withZ10PE-D16-WS 3403 + APTIO work-around now results in N/A uCode in bios.
50mv 0x39 .EFI hung during linux boot... trying another...
v3x2_50_x32_vcc.efi
V3x2_cup32.efi
Keyboard unresponsive, have to hold power button to turn it off. You guys with this board setting anything in the BIOS? Everything is default.
I've tried all the various .EFI files throughout this thread (all the V3x2_xxxxx.EFI anyway). I also tried no .EFI file and as you say, it behaves the same whether I have one or not.This is pretty similar to what I saw on windows boot when I tried (same results with no micrcode efi driver also)
Did you disable C3/C6 states in BIOS ?hung during linux boot... trying another...
I can confirm that the various .EFI load and print their messages (without error). I can also confirm that the uCode reported in the bios is N/A as it should be and 0x38 with the "stock" BIOS.
So, unlike the single processor boards, I'm completely unable to boot at this point.
My PC (EP2C612WS 2x2686v3) works fine in Win/Lin with v3x2_cp39.efi only when C6 disabled.
But when uncore is forced ("cup" version of efi driver) C3 must be disabled too.
I did (had been following the thread on that issue) but I'll retry the experiment this weekend.Did you disable C3/C6 states in BIOS ?
I was going to start a github project for future modifications - can I use your sources as a base? I've asked you in this thread ~2 weeks ago, but since you didn't answer then - I was too lazy to make a complete rewrite before publishing)
Hi,@Welsper :
@randir :
I would be highly interested in your sources as a starting point, however the link posted earlier is not working anymore.
I would gladly participate in your development and github project.
I own a 2696v3 R2 and Asrock X99E ITX... so far I got 3.2 Ghz allcore, however only light loads. Even non AVX loads that are a bit more intense and my multi drops, due to I believe power restrictions.
I need to find out more.
Anyway if you would reupload your sources i would be very happy indeed.
Chris
I also have a X99E-ITX/ac with a E5-2683 v3.
Z10PE-D16 WS + 2696v3 ES - works only with V3x2_cp.efi and V3x2_cup.efi
Yes.I have a dual boot system Windows/Ubuntu, is the EFI driver also working on Ubuntu then? (might be a stupid question)
Same problem. On the load: CPU has about 136W during 56 sec then falls to 120W.It can't rise above Nominal
Z10PE-D16 WS with pair of 2696v3 ES (C0/C1) (results)
(win 10 x64 Pro)
Z10PE-D16 WS + 2696v3 ES - works only with V3x2_cp.efi and V3x2_cup.efi - stable and similar with results mentioned here. Other efi drivers freezes during loading (it could set +38 for all cores for 1 CPU and freeze during setting second... etc...)
For my part, I started with 3403 - made an edit to work around the APTIO issue (described in this thread) and then ran ubu. This succeeded and produced ucode version "N/A" in the bios.Can you link to specifically which BIOS and EFI you used for the D16-WS? also, what bios settings did you tweak? Thanks!
I disabled C3 and C6 - made no other bios change
I then tried all the V3x2_xxx.efi I could find in this thread (including _cp, _cup, _vup32, _cup27, cp27, cp39, and the 50/vcc versions as well)
I haven't tried the other 2 BIOS posted to this thread recently yet. Result was always the same and the same as if I did not run the .efi at all... linux gets to "setting hostname" and hangs. power/reset unresponsive. Same exact place each time.
In all cases, the banner of the .efi file appeared and reported "success" in the various ways that each of them do...
No, none have worked for me at all on the Z10PE-D16-WS... all hang the same way including no .efi at all...You said that v3x2_cp and v3x2_cup both worked, though? I'm debating giving this another try.
