what card to get... since my radeon 64ddr wont work on my pc?
aUt0eXebat
Banned
Oct 9, 2000
2,353
im thinking v5 5500, but ive heard 3dfx is going out of business or something... any other recomendations? the geforce2 gts is a power hog and my ps isnt that big (230)... so what do you recommend?
aUt0eXebat
Banned
Oct 9, 2000
2,353
well, i took off my old 3dfx drivers, put in my radeon, formatted my HD, installed 98, put the radeon drivers in, (newest ones) and the openGL settings tab in the display, it froze whenever i tried to go into it, and it froze when i got into outlook express. all this started happening when i put the drivers in, it even did this with the older drivers. and in safe mode........
BW
Banned
Nov 28, 1999
254
He really shouldnt have to though.I mean give me a break the radeon should work fine without all the reg tweaks and hacks.WTF.Go with the 5500 and play everything with no problems.
BW
Banned
Nov 28, 1999
254
Paldo thats cool for not dogging me on what i said.I didnt relize it was the 64 meg version.It should be faster than thee 5500 in 32 bit. That itself is a card ide like to have.I have the 32 meg ddr.The truth is though if he cant get it to work the 5500 will give him less problems of all the cards.Laterz.
aUt0eXebat
Banned
Oct 9, 2000
2,353
i have been for 2 days, and it keeps doing the same things over no matter what I do. the card works, but when i get the drivers put on for it, then it starts screwing up
BW
Banned
Nov 28, 1999
254
The radeon should work on your system. Rage3d forums should help you. That is a sweet card i hear.
Taz4158
Banned
Oct 16, 2000
4,501
<< i have been for 2 days, and it keeps doing the same things over no matter what I do. the card works, but when i get the drivers put on for it, then it starts screwing up >>
Any IRQ conflicts at all? Also important to run MSCONFIG and remove all ATI references from the startup tab. Do a find for ATIGART.EXE and rename it or delete the folder. This should solve it for you.
aUt0eXebat
Banned
Oct 9, 2000
2,353
i did go into msconfig, unchecked all ati stuff. and i got rid of the atigart too. didnt help, deleted ddhelp, still didnt help. i mainly had problems with outlook express, when it loads, it freezes there. it started once i put my ati drivers on. and the openGL setting tab, locks up when i click it too....
aUt0eXebat
Banned
Oct 9, 2000
2,353
i formatted 3 times, still did not help any. i installed the drivers from the CD first then the latest ones from ati's site
aUt0eXebat
Banned
Oct 9, 2000
2,353
well the mobo is 815e, and in the BIOS it says 64mb (for the vid) and 4x for the AGP
whats weird is, when i got my Dell, it came with an ati rage 128 card in the agp, and it worked fine, then i replaced it with a voodoo3. that works great, now i want my radeon to work... but its not....
Taz4158
Banned
Oct 16, 2000
4,501
Reduce the AGP to 2X and see what happens. No fastwrite option? If so the Rad doesn't support it.
aUt0eXebat
Banned
Oct 9, 2000
2,353
i dont think theres a fast write option, if there isnt, the radeon wont work right?? i dont think i can change it to 2x, ill try later though.
oldfart
10,207
Remember, he has a Dell. A Dell bios has very few options, no tweaking options like an aftermarket mobo.
Workin'
5,309
<< i installed the drivers from the CD first then the latest ones from ati's site >>
That's possibly the problem. Don't install the drivers from the CD at all - just install the latest ones you have.
You might also look around and post this question at the forums on Rage Underground.
It would be absurd if the card didn't work with your machine, esp. since it came with an ATi card.......
aUt0eXebat
Banned
Oct 9, 2000
2,353
hmm..... well, i tried the rage3d boards, but they said there not taking anymore members right now.....
