What card to get? CSS and web design
thespeakerbox
2,654
I'm looking for a video card for my new build and dont know if if the 7900gt or x1900xt would be overkill for a gaming/ design rig.
Gaming is only CSS.
I know the 256 x1900xt is a good buy now , but think it may be overkill. Or the is it just right?
What do you think?
schneiderguy
10,801
what resolution are you going to be playing at? at anything less than 1280*1024 a 7600gt would do, higher than that i would reccomend the x1900xt
Munky
9,372
If the x1900xt offers more bang/buck, what's the point of getting a cheaper card?
thespeakerbox
2,654
Well , if i get a 7600gt cheap now, i would shoot for a x1900xt when DX10 comes around. Maybe ill be able to pick up a good deal.
Wreckage
Banned
Jul 1, 2005
5,529
He only plays CSS at 12x10. I don't think the extra $100 will get him more bang for the buck.
josh6079
3,261
True, but he said that he plans to go to a widescreen monitor in the near future and the resolution would then probably be closer to 1680x1050.
OP, the 7900GT or the X1900XT would do you fine. Unless you want to give us anymore future plans or specifics, flip a coin.
NoStateofMind
9,711
Well I Just built a new system with an X1900XT (512 version) and all O pretty much play is DOD:S. It's a source game so its close in oerformance in what you would get. I'm 90+ FPS all the time at 12x10 all settings maxed. I'm satisfied and I think you wouldnt regret it either :)
akshayt
Banned
Feb 13, 2004
2,227
I would suggest thay you get a 1900XT, as no other card may let you play at:
1280*1024 MAX
6x AAA
16x HQ AF
TheRyuu
5,479
14
1280*1024 MAX
6x AAA
16x HQ AF
X1800XT Will
CS:S is not that demanding of a game.
But he said he wanted to upgrade maby in the future to a WS (most likely 1680x1050) then he will probably want that X1900XT (i'd get the 512mb version while you still can)
DeathSniper
Uh...I have a GF6800GT and I game at 16x10 max settings just fine. If you turn down/off the AA & AF for multiplayer, my fps hovers usually 70-140...
In HL2 with settings maxed and 4xAA, 8xFF I get 35-70fps, which is certainly playable.
CSS is not that demanding of a game...
secretanchitman
9,353
23
6600GT here at 1280x1024 all settings maxed, 2xAA, 4xAF.
that shows you how capable my card is.
7600GT/7900GT/7950GT or the equivalent ati cards are good for you. dont go too expensive if you want to save up for directx10.
akshayt
Banned
Feb 13, 2004
2,227
No, it is not. Open box means refurberished and only comes with 15-30days warranty AFAIK.
I would rather spend few dollars more to get 2-3yrs warranty. Few days back there was a 1900XTX selling for around 300$ after rebate.
razor2025
3,010
seems super overkill suggestions.
I have a X800 GTO^2 OCed to X850XT PE speed and CS:S auto-detect my setting at 1680x1050 on max detail, Full HDR, 8x AF, 4x AA. Even in CS_Office, the FPS hovers around 40-50 fps (30 min). You can easily get a X850XT or GTO^2 for ~$100 now. No need to blow $300 on a card.
happy medium
14,387
480
Originally posted by: GundamSonicZeroX
May I suggest the 7900GS just in case Valve makes the game (or one of their future games) more stressful.
I second the 7900gs if you can get the 150.00$ best buy deal.
Should be more than enough for CSS at high resolutions.
http://www.bestbuy.com/site/olspage.jsp...ctCategoryId=cat01151&id=1155072371459
Edit : Something I took from another thread. This guy has a 1800xt and a 3800 x2 and scores 138 fps in CSS at 1680 x 1050
11/05/2006 11:05 PM
CCityInstaller
Senior Member
1680x1050 All High, Max 6XAA/16XHQAF 138.5fps...
Abit AT8 32X Crossfire MB
A64 3800x2 @ 2.67 Ghz with AC Freezer 64 PRO
2 GB OCZ EL PC4000
HIS X1800XT w/ AC Accelero X2
Seagate 7200.10 320GB SATA HD
NEC 3550 DVD burner
Antec Super LanBoy
Antec Neopower 480W PS
Acer AL2032WA 20.1" WS LCD
Munky
9,372
Guys, this thread is over 2 months old, for chrissakes. The OP isn't even posting anymore.
happy medium
14,387
480
Yea, X-nice why did you revive it. Well I feel like a moron:roll:
XNice
1,562
haha, i jus realized that this thread was that old. oh well. people like munky just need to get laid so he wont spend so much time on AT allowing him to complain about reviving old threads.
