Buy a car you can afford to pay cash for and stop worrying about labels and looking cool.
I personally like the new Camry, although Camry is traditionally a boring middle aged person's car.
Source or are you assuming?
Willingness to spend $40k on a car but concern over buying gasoline which costs 20 cents per gallon, meaning only a few hundred dollars per year, boggles my mind.
Parents' V6 Hondas owner's manuals. (If you want page numbers you'll have to wait until next Christmas when I'm visiting family again.) I believe that Honda may have changed this on newer models, but I do know that the Pilots recommend Premium when towing anything over 3,500 pounds. This would tend to indicate that the ECU cannot back off enough to allow the use of regular when the engine is loaded above a certain point.
Or were you asking about my source for the Acura comments? You know, the comments for which I explicitly used terms like "may" and "AFAIK"?
ZV
My previous '09 V6 manual Accord listed regular gas in manual. No premium at all. Same for current Pilot.
Edmunds lists the '13 V6 as regular gas as well.
I was asking for source of your claimed statement: if you want the rated horsepower of Honda V6, you have to use premium fuel. I never heard such a thing from Honda, only Hyundai turbo 4 cylinders.I know that the Honda versions only "recommend" premium fuel. Basically, if you want to get rated power, you do have to use premium, but the engine management computer has sufficient range of adjustment to allow the continued use of regular fuel without damage.
AFAIK, it's mostly engine management tweaks between Honda and Acura engines. I know that the Honda versions only "recommend" premium fuel. Basically, if you want to get rated power, you do have to use premium, but the engine management computer has sufficient range of adjustment to allow the continued use of regular fuel without damage. Acuras may have a different ECU calibration that doesn't allow the use of regular gasoline though.
ZV
For a 2012 Honda Crosstour 6 cylinder engine, here is straight from the owners manual P. 282 on Fuel Recommendation:
"Your vehicle is designed to operate on unleaded gasoline with a pump octane number of 87 or higher. Use of a lower octane gasoline can cause a persistent, heavy, metallic rapping
noise that can lead to engine damage."
Keep the accord. Spend the money on hookers and blow... yes I am serious.
