what can you dumbell shoulder press?
91TTZ
14,374
Originally posted by: Rogodin2
Was this before or after you suddenly became 6'6 and totally shredded?
I've been 6'6" and shredded since 11th grade.
Rogo
Are you 6'6 and shredded in real life, or just on the internet?
Any pics?
Koing
Elite Member <br> Super Moderator<br> Health and F
Oct 11, 2000
16,843
Originally posted by: 91TTZ
I don't do them with dumbells.
I was able to do a 225 lb barbell 8x though (sitting down). I'm not sure why I have such an easy time with this one, people say that much weight should be hard. I'm not huge or anything, it just feels light.
I can't do them the way Koing does, though. My back has too much of an arch in it and bends under the weight.
Isn't that a function of core strength?
Probably, but I never lifted like that. I always used the shoulder press bench at the gym.
Hell, when I started squatting a few years ago, I could only properly squat 135 lbs. I could legpress a lot, but a proper squat is much harder. Koing does the real deep squats which are even harder than the conventional squats. Since I don't train to do them, my legs would probably just give out if I went that low.
Shoulder press bench? But your still using free weight and they aren't weights attached to a machine?
225lbs x 8reps is a F0CK load to military press standing without a machine and not using your legs! Even on a machine it is a lot but not nearly as strong.
Yes it is a funciton of keeping your body (abs and back) strong when pressing.
Koing
Red Dawn
57,529
I just use a machine. I kept injuring my shoulder when I would get into heavy weights (being 53 the old shoulder joints aren't what they use to be) With the machine my max is 250 lbs 8 times. I'm sure it would be significantly less if I use dumbells but who cares, it's not how much you lift, it's how much you look like you can lift.
paulxcook
4,277
You are a wise, wise man.
crt1530
3,194
Ahhh...the Justin Timberlake approach. When's your next boy band tryout, Red?
Looney
21,938
If you arch your back you're using more of the chest and back muscles.
Koing
Oct 11, 2000
16,843
LOLOL!
It's different when your 50yrs+. Your joints and your body aren't like what they use to be when you were 18. Hell guys at 24-27 complain about feeling old...
I'll Olympic lift for as long as I can :)
Koing
Dec 10, 2005
29,187
14,553
When I was going to the gym at school, I was doing 35-40lbs in each hand for dumbell shoulder presses using an inclined bench - 3 sets of 10 reps each. I'm only 19 - 140lbs, 5'11".
Red Dawn
57,529
I honestly haven't the foggiest idea what you are going on about.
