balloonshark
- Jun 5, 2008
- 7,313
- 3,739
- 136
https://support.malwarebytes.org/cu...malware-replace-antivirus-software-?b_id=6438I don't understand why people use Malwarebytes with another anti-virus. This could cause issues with two scanners running at the same time. Best would be to run your browser in Sandboxie.
Does Malwarebytes Anti-Malware replace antivirus software?
Malwarebytes Anti-Malware is not meant to be a replacement for antivirus software. Malwarebytes Anti-Malware is a complementary but essential program which detects and removes zero-day malware and "Malware in the Wild".
This includes malicious programs and files, such as virus droppers, worms, trojans, rootkits, dialers, spyware, and rogue applications that many antivirus programs do not detect or cannot fully remove. That being said, there are many infections that Malwarebytes Anti-Malware does not detect or remove which any antivirus software will, such as file infectors.
It is important to note that Malwarebytes Anti-Malware works well and should run alongside antivirus software without conflicts. In some rare instances, exclusions may need to be set for your specific antivirus product to achieve the best possible system performance.
You can also find a MBAM/AV compatibility chart PDF on this page.
https://www.malwarebytes.org/antimalware/premium/
