I live in El Paso, Tx. and the days are hitting 100. As I am surfing the web my computer is running at 42 degrees with a motherboard temp of 31 degrees according to the program Motherboard Monitor 5. I have a ThermalRight SLK-700 with a YS Tech 74mm T.M.D. fan. My CPU is a an XP 2100+ running at 12x180mhz(2160mhz). Is this normal? What are you guys getting with the same or very similar setups?
