First, you must stare at the soda machine for five minutes because you've never seen the flavors offered before.
Second, after you've selected your flavor(s) you must fill the cup with ice.
Third, you must dump out half the ice and occasionally add a little more.
Fourth, you must fill your cup with your chosen soda unless it's too carbonated, in which case you switch to flavor two.
Fifth, you taste the soda and make a face.* (*note) making a face apparently signifies neither good or bad.
Sixth, in the case the face you made meant it was actually bad, you dump it out and start over.
Seventh, in the situation where your favorite soda is out of syrup or carbonation, under no case will you notify management. The corollary also works, you notify management every time you come in that the soda doesn't 'taste' right.
Eighth, after finally receiving your filled drink you must choose the wrong size lid (even though they're labeled) and discard the lids that don't fit on the counter.
Ninth, after finding the correct size lid, you try multiple times to stab a straw through the lid, leaving the wrappers and bent straws from unsuccessful tries on the counter (even though there is a trash receptacle inches away)
Tenth, because of the high tech involved and the temperamental nature of soda dispensers, you must use at least 25 napkins to try to clean up your mess and then leave them on the counter (see number 9).
