What's the difference how much longer ball bearing fans last than sleeve bearing fans. Sleeve bearing fans are cheap, quiet, and often come in multiple packs to use as spares.
For example:
COOLER MASTER case fans such as:
http://www.svc.com/r4-s2s-124k-gp.html
R4-S2S-124K-GP 4 PACK 120MM LOW NOISE FAN 44.73CFM 19.3DBA
Four for $9.99
John
I'll step back in here quick, those fan are not, Not, NOT 19dbA. They're about 19dbA above an ambient reading of 19dbA, lol. They're a little quieter than my 60cfm 39dbA evercool cheapies and don't nearly move as much air.
Sleeve bearings generally have an MTBF of just shy of 3 years whereas ball bearings are about 5 years. Proper re-oiling of a sleeve can stretch it to about 5 years and re-oiling a ball bearing can push it to about 8.5 years. Obviously that is giong to vary by as much as 25-30% depending on build quality. Any imbalance in the actual rotor/blades of the fan is going to cut it's life by 10-20%.
These Cooler Master sleeve bearing fans sold in two-packs by Newegg are similar. The user reviews seem to indicate that they are quiet and cheap.
http://www.newegg.com/Product/...x?Item=N82E16835103022
If they are quiet and cheap, I still don't get the logic of spending $20 plus on a ball bearing fan or two or three.
John
Then you'll have a hell of a time explaining why aigomorla has a thousand dollars worth of water cooling stuff sitting in a box and why I'm spending about $300 to cool my 4 year old hardware to -25C huh?
It's just what we do. :shrug:
Then for you it's worth it. Not all of us spend that much as I am sure you are aware. I am not sure if the OP spends that kind of money either.
From his post:
I want 120mm fans (2 or 3) and my priorities are:
1. Quiet
2. Moves decent air
3. Not too expensive
Probably the least important of those 3 is air movement, because my system isn't that high powered:
Now I believe we are participating in this thread to help the OP meet his needs. Right?
John
I haven't found anything here offensive or off topic, including the discussions between the two of you. I stated my ideas in the OP, but I was pretty naive at that point and I've been learning a lot in following what's been going on in this thread. Please feel free to speak your minds. And thank you for the education.
Speaking for myself, I figure it's worth something to buy fans that are apt to last longer just so I'm not inclined to wonder, "are my fans failing? Is my system getting a little louder?" With BB fans, in particular what is stated as the superior BB technology of the S-Flex fans, I figure it's unlikely they'll get louder any time soon, especially since I don't leave my system running when I don't expect to use it within the next hour or two (i.e. I shut it down often, don't let it run overnight, etc.).
I did have a vexing system failure situation a few weeks ago, which led me to this point. Motherboard failure (and it took out a PSU and 2 vidcards!), and I figure that cooling was a contributing factor. I had no intake fan and 2 exhaust (including the PSU's exhaust fan). I figure I should add an intake fan and swap out the 80mm I had for a 120. I wasn't happy with the noise of the PC as it was, and wanted to do something about it. Now, since I'm rebuilding the system I figure that the addition of two 120mm's and removing the relatively loud 80mm should address both problems (cooling and noise).
