Originally posted by: mx1mx1
Well I just went to several different stores and looked at dozens of monitors.
I looked at 4 different Trinitrons. One was a Sony E400 19" 2 were HMD-A440 19" and one was the Sony 21" I think G520??.
keep in mind these were at 3 different stores. Compusa, Circuitcity, and RC Willey and guess what?????
THEY ALL DO IT. Yup every 19" Trinitron CRT that I looked at did it.
So I have personally now seen 6 CRT Trinitrons do it.:disgust:
Well i also looked at every LCD in the stores and none of them do it, but LCDS suck.
So I drove on down to one more store and they had some necs, the FE991SB 19" and the 17" Nec,
I think the FE771SB.
interestingly enough the 19" inch Nec did do it but the 17" did not do it.
infact, I think just about every 19" CRT I have ever seen does it.
Maybe this is a 19" and up CRT thing?? I know for a fack LCDS dont do it.
And the 17" Nec sure did not do it.
Strange indeed.
when NVIDIA released the GF3 Ti 200 and 500 they also released the Geforce 2 Ti, it sits between the Pro and Ultra cards Link.Originally posted by: MrFiTTy
I am using a Geforce 2 Ti
Since when can you get GF2 Ti's ?![]()
When my buddy came over to try to help me fix the problem he could not see it at first. he really had to sit here and look at my monitor for probably 10-20 minutes before he finally started to see it.
So they really are hard to see. You almost have to look at the monitor in a different way.
I think the easiest way to see it is to open IE witout opening a webpage, (just so it says, this page cannot be displayed or action canceled) Then look there in the white parts of the screen in the corners.
All trinitron monitors have that "problem" you're talking about. Sony licence's out the trinitron technology and so that's why any monitors using it have the black lines.
Originally posted by: Yomicron
Are you talking about Moire? If it is Moire then the lines should be easier to see on a gray background. Your monitor should have Moire settings, try adjusting them.
