nick1985
- Dec 29, 2002
- 27,153
- 6
- 81
Originally posted by: iversonyin
he said he dont need top of the line gaming card and for $144 you get a SE with the potential of pushing to 9800PRO without any risk, softmodd has no risk as far as i know
even if you don't softmod it, its still a good card for the value.
why bother with 9700 PRO, they are used or refurbished everywhere for $120-130, its jus not worth it
First, without any risk? Here it shows a non softmoddable 9800se is below the 9500pro and just above the 9600pro.
Second softmodding has quite a bit of risk. Softmodding allows the 4 unused pipelines to be opened thus haveing an 8 pipeline card insted of a 4 pipeline. The highest softmod percentage is in the Powercolor 9800se C3 and that only has a 67% success rate. Also, unlocking the other 4 pipes creates more heat and a need for a better cooler if you are going to over clock/flash to pro speeds.
Why bother with the 9700pro? Because it proforms almost up to 9800pro standards (within 5-10fps) for at least 30 dollars cheaper than the 9800pro. On a tight budget that is a great savings. Also, in your last sentance you demonstrated how good of a deal they are but then said they aren't worth it... hmmmm... Are you implying that because a vid card is cheap it isn't good?
and according to this guy, there almost no risk at softmodding.
sounds reputable....:roll:
