Ronin
Originally posted by: zixxer
Originally posted by: Ronin
Westinghouse 37"/42".
out of my price range
You said under 2k, right? The 37 is 1400, and the 42 is 1700. Might want to clarify your range.
Originally posted by: 91TTZ
That is NOT a HDTV. That is an "EDTV"
HDTV is 1280x720p or 1920x1080i
arg...
anyone want to recommend a tv at least 42 inches for around $2k?
Originally posted by: Abel007
1024x768 is HDTV. It can accept a 720p signal and will leave small black bars across the top and bottom and not use the 48 extra pixels.
Enchanced TV is 480p. Standard TV is 480i.
The reason 1024x768 is frowned upon cuz its not pixel perfect for a 720p signal (720 horizontal lines) nor a 1080i signal(540 horizontal lines). That being said, a plasma is not a bad purchase because of those wasted 48 pixels. It is a better picture than most LCDs in the same price range. I suggest visiting www.avsforum.com for any other information you need. Great resource and the people there are extremely knowledgable.
http://www.hdtvinfoport.com/HDTV-Resolution.htmlThe Standard for HDTV-Resolution is (any) one (1) of three (3) specified resolutions:
720p, 1080i and 1080p
Originally posted by: venk
Someone else said it above. The Pixels are not standard 1:1, they are wide. Akai makes a 1024x1024 Resolution Plasma with 16:9 Pixels.
The reason 1024x768 is frowned upon cuz its not pixel perfect for a 720p signal (720 horizontal lines) nor a 1080i signal(540 horizontal lines). That being said, a plasma is not a bad purchase because of those wasted 48 pixels. It is a better picture than most LCDs in the same price range. I suggest visiting www.avsforum.com for any other information you need. Great resource and the people there are extremely knowledgable.http://www.hdtvinfoport.com/HDTV-Resolution.htmlThe Standard for HDTV-Resolution is (any) one (1) of three (3) specified resolutions:
The standard does not include 1024x768.Originally posted by: Koing
1024x1024 is an ALiS screen.
'technically' 1024x768 is 'correct' to be a HDtv. It can display the 720p signal. The standard is FUNKY in the way it stipulates the vertical resolution and 'not' the horizontal resolution to go along with it.
I would not call a 1024x768 display being HD even though the standard says otherwise. It doesn't show the rest of the horizontal resolution FFS! It should be 1280x720 minimum!
Koing
Koing
How do you figure?Originally posted by: Koing
Koing
Correct but it does show 720p which 1024x768 does do.
Yes, but AFAIK, 720p stands for 1280x720 progressive, not just any resolution with 720 horizontal lines.Originally posted by: Koing
768 - 720 = 48 left
It can 'display' the 720p lines in full unlike the 848x480 plasma screens which can display a 720p signal, but it is downscaled to fit. 1024x768 of course doesn't display the vertical lines.
Read the link a few posts above. The HDTV standard is funky in describing it this way. It only describes the vertical resolution needed to display and not the horizontal also.
Koing
You mean after scaling?Originally posted by: Abel007
1024x768 is capable of displaying a 720p image therefore it is considered HD.
