n0cmonkey
I see what your saying, and it is a logical arguement. I would say my response is somewhere in the middle. The study counted not only "Windows" but also MS made server/apps for windows (as far as security holes) and, it took things like RH or Debian, and looked at everything that makes up Linux. You are right in that a lot of things are redundant, and most people wouldnt use half those things. However, the same arguement (not to that scale) could be made if "I dont use SQL Server".
The second part of the report was lag time between the bug, and the fix. Which found that on average MS was far faster at releasing a fix. What is your thought on this finding? Do you feel that it is inaccurate?
However, people tend to act as if MS software, and only MS software has Flaws, and said flaws go unfixed for months. Which, is simply not the case. I would say that the second finding of lag time is more damaging than simply the ammount of Flaws.
Drag
Say that you have to keep all spyware or adware off of all your windows computers, if a single computer gets infected will you get fired. What would you do if your running windows?
Disable ActiveX for starters(on non trusted sites), and prevent users from installing any unapproved programs.
Ah, I think that something like that would be unreasonable.
Not at all.
You go into the hosts file of the Linux DNS server the school used. Make it when they typed in
www.xxx.live.com it would go to nothingness. Give me a break. If I had access to the server, (which a part time temp assistant doesn't have) it would probably take less then 2 minutes. Hell I probably wouldn't even have to walk into the server room, I'd just ssh into the server and be done with it.
Interesting solution, but what if you wanted to give half the room access, and the other half not
Not important for an XXX site, but maybe for an intranet - secondly, accomplishing that task was only the first part of the issue. You are replaced by someone next year, people are reporting that they can no longer get to several sites (policies changed) - would your change be the first place the new admin would look? Generally, messing up DNS to fix a problem is not the first place I would start to fix one.
Which is the core of my point, this was "Drags Solution". Did it work, sure, quick too. Would anyone else have a clue where you did it unless you told them, maybe.
Just because you don't have a clue on how to run a bunch of Linux machines, doesn't mean that other people don't, and that you can't find effect people to do it.
Again, I wasnt implying it COULDN'T be done. My point was there is no standard way to do such things. You gave me several solutions to the problem, all of which would most likely work, some better than others. I would bet there are others as well, just as in a windows enviroment. However, in windows - most are agreed that everything should be done via a Group Policy. Any new admin can come in and be told "I cant get to this site" and the first place a competent admin should go is into the group policy.
And, this was the first example I could come up with. Most people who tend to defend linux to the day they die never have seen the policy manager, or how it works. So, before I go on, do you have any experiance creating/using group policys, and the level of detail you an control?
I thought that since Windows is so easy to use that any moron can do it? Sorry, Windows just isn't easy. It realy isn't, it's a hug pain in the rear to keep running, irregardless of what you may or may not think about the difficulty of Unix-type OSes. At least when you set it up you don't have to worry about something spontaniously changing.
Windows is as complex as you want to make it, however with the 2000 and 2003 releases, things simply don't change. There isnt any thing I can say or show that can make this point anything other than anecdotal, just as your claim to me is. I dont know what in your experiance has just stopped working.
I personally have been amazed with the roubustness of things such as DFS, Previous Versions, and NTFRS working together. I have a client who has 3 locations, they are an AutoCad shop that does city design. They have 70 gig of data that needed to be available in all 3 locations, always up to date. These locations are only linked by DSL lines (They are cheap too). However, these files are rather large, and simple VPN file sharing is way to slow. The solution was implemented over 1 year ago to this day has not needed any tweaking or support. We setup a server in each location, we setup a DFS (Distributed File System) with a Hub-Spoke topology, which remote links in each location, which made a replica set of all the data in a share at each location. As soon as they hit Save on a file, NTFRS (nt file replication service) starts streaming the changed files to remote locations. What is even more interesting is if one of the DFS Sites is down, Windows (transparatenly) will resort to contacting one of the other replica sets without user interaction (all configurable of course). One plus on this is Previous Versions, a new 2003 feature that makes a hourly (configurable) backup of all changed files on a shared volume. So, if a user deleted a file they shouldnt have, they can right click the folder, open it up as of "yesterday" and retrive it.
But, that is anecdotal evidence. I cant prove its roboustness, I can only share my experiance. I found it rather impressive that a few hours work can do something the company only dreamed of. And it has never failed.
No you weren't. Who the f*ck goes around messing with those settings? Nobody, but they still got screwed up. Don't ask me how they did, I am sure that some MS tech somewere could explain what happenned if they knew the details.
When people start to troubleshoot things they dont know, the registry becomes a fun place to screw things up
Look, things just don't work sometimes in ********.
Fixed that for you
At my current job we have a w2k server, it has automated backups that it does every week. A few times every year it would just fail to run the backup correctly. Why? Nobody knows. You start it and it will just run just fine, and then the next dozen backups will run, then some months later it would just not run the backups. Whatever.
Something tells me you are using Veritas, maybe even 9.0
I have had issues with Veritas (recently) doing things consistantly. However, I also know its not a windows problem, they are separate things. As Computer Associates backup runs just fine everytime.
Sure. Windows appoligists still say that Windows has 10000X times the viruses and worms that Linux does because Windows is 33x more popular. So why can't I say that Linux is more stable?
Because they arnt related. If you had said "Spyware and Viruses arnt much of an issue on Linux" that is a true statement, however it is not a question of stability. I believe it is more a matter of stupidity, and I think we can agree here, Windows has more idiots using it than any other OS.
I get a "my computer has all these weird bars/slow/popup all the time" call weekly. It is never a Linux box, or a Mac. Does this mean windows is less secure? Perhaps, only in that it asks the user to say "Yes or No", and since most users are Administrators, things get installed. And if you wanted to pick out one of the only 2 main security flaws I find in windows, this is one of them. People should NOT be using an administrator account by default, especially one with no forced password. (the second would be allowing access to raw sockets).
That said, it is not an unreasonable claim that since windows is the most used OS it is also the most targeted for crap.
If your running a unpatched windows machine on the internet and your surfing around, you WILL get worms installed on your machine. You WILL get spyware installed on your machine without any user intervention. Nobody ever got "Mydoom would like to install a spam relay on your computer, is that ok? (Y/n)"
You will get hit by some worm yes, if your unpatched/unfirewalled, no disagrement there. Spyware most people get by a some freaking "What Smilies in your email, Click yes!" crap on a website. However, there are flaws in ANY os, people get rooted too you know. Windows is quite simply at a disadvantage because it is the biggest target.
Look, I think your a bit wrong about how easy it is to run Windows. Maybe it's because you've probably have been using it for 10 years or so, or maybe it's because your a developer, but it's not easy.
I was only trying to imply that it is a lot easier to administer a large network of desktops via windows. Most people tend to agree with that, they tend to feel things like collaboration software and true group management are still not ready yet or in some cases dont exist yet.
Why do you suppose their is a huge sticky thread on how to aviod spyware and crap-whatever-ware at the beginning of software forums? Because Windows is easy?
Its not a mater of ease, but stupidity. When Windows is telling you there is a critical update, and you click "No" you deserve all the spyware you get. If you want Comet Curors, you deserve what you get. If you ignore all the prompts to update your computer by going to one stinking website, you deserve what you get. Also there are programs that are "free" but contain GAIN or something of the like. Those are middle ground things, which could happen on any OS if any of them cared to target them. If its embeded in the app you want to use, you are screwed no matter what OS you have.
That's because the people that you talk to or are around this stuff truely like windows. It's just your group. I've met people that love windows, but they are at the huge minority. The reality is that most people don't care, they'd be running WinME if their computer came installed with it.
There are alot of people on both sides, some as you say dont care, others demand XP. I guess, I am seeming more of the "Does this have XP" than does this have "Windows" type questions lately. I have actually gotten 2 "what is longhorns" from end users in the last week. One thing I have seen is a huge change in the amount of MS hate, it has been dropping in my clients. While spyware is their main issue people have most realize it is self inflicted.
Out of the people that do care, the majority of them dislike Windows generally, but believe that's the normal state of things. That this is "normal" with software, because that's just what they are familar with. A minority "like" windows, just like a minority "like" linux.
Could be, I havent found many people outside of a LAN party or a forum that seem to "hate" windows recently. (outside of WinME) But I also havent found anyone that "hates" Linux lately either.
Do you think that a OS is that a important fixture of most people's lives that they bother to assign a emotional response to it?
Only to the bean counters lately
Nothinman
If that's what happens chances are the blame is firmly in MS' lap because it's their API they're publishing and any changes or deviations will probably come from their future releases.
That is totally possible, but to me a hack just to get a few specific features done is equally as possible.
And, Yes I know about WoW and I also know that in a lot of cases it doesn't work well because chances are if you need to emulate something like Win95 the app will do something stupid like try to access hardware directly, if the app was actually a well behaved Win32 app it would work without WoW.
Emulation is never perfect, however I have had more success with using it than most.
Huh? Maybe I missed something, but I didn't see any flaws mentioned in this thread.
It was in a PDF I linked. Not liked to well, but it shows both are not perfect. It also showed that MS is quicker at fixing them (on average) by a good margin.
There used to be a web page of unfixed bugs in IE, but IIRC MS made them take the site down.
Bugs and security issues are different things. However, I am not trying to paint MS as perfect. Are you implying that Linux as of today is "perfect"
However, based on history, MS is on average 25 days to fix a published bug, where as it was higher on linux. (Remembering this from memory).
