Originally posted by: 2112Rush
I've read a little about Linux. But I don't know enough to make try it. I don't know much at all about computer stuff. I just built my first one. And of course am having all kinds of problems. I wish I had more time for tinkering. 🙂
If you want to have a "no commitment" dive into linux, download a LiveCD image, basically, its a fully bootable, usable linux distro on a CD. Boot/load times will be horrendously slow, because everything needs to be read off the disc, then decompressed, then run, but it's pretty amazing that the whole OS, and a host of apps, tools, and utilities fits on a single CD. Since you're not installing linux, there's really no prerequisite knowledge needed in this case.
A LiveCD also makes a really good hardware troubleshooting utility because the software configuration doesn't change. If you're NIC goes all loopy on you for no good reason, you can boot off the liveCD and check it out. If its also broken from the livecd, then you probably have a hardware problem.
For this second reason, I'd actually recommend grabbing one, like knoppix, and burning a copy to play with in your tinker time.
