If you want the low down, either look on Xtreme, or read below. http://www.xtremesystems.org/f...howthread.php?t=178989
I can tell you something about the drive, I have 3 of the WD 640GB, using 2 currently. I bought them for a server because they have "fast transfer rates" and are quiet, didn't know squat about access times. I have been doing VERY EXTENSIVE network testing wiht a bunch of different gigabit NIC cards and onboard LAN chips, a SMC 5port switch and a HP Procurve 1800-24G. Linux Ubuntu/Mint OS on both systems, both using Intel Pro1000 9300PTBLK PCI-e x1 cards and current drivers. I was really hoping to get 60MBytes/sec througput as a goal for an unRAID box. Here is some test results hot off the bench using VSFTPD on as a FTP server, commands for sending/receiving files to eliminate software settings. Sending a Mint Daryna CD ISO back and forth got these results.
I did a get (writing to Hitachi 164GB drive in the "PC") from the WD 640GB "server" and it took 20.17sec @ 34967.3KBytes/sec.
I did a put (writing to the WD 640GB drive in the "server") from the Hitachi 164GB "PC" and it took 7.21sec @ 97847.7Kbytes/sec.
I just replaced the "PC" 164GB Hitachi with a WD 640GB drive now.
I did a get (writing to "PC" now using a WD 640GB) from the WD 640GB "Server" and it took 9.51sec @ 74113.1KBytes/sec.
I did a put (writing to the "server" WD 640GB drive) from the "PC" WD 640GB and it took 6.89sec @ 102283.4Kbytes/sec.
NOTE: The previous best writing to the "server" with a Hitachi 80GB SataII was about 50MBytes/sec.
I think the WD 640s are some kick arss drives, don't you?
