Thanks for a very helpful reply, Mac!
"Inspired"... Is this an apology or a rationalization? You mean you're ready to go cheap. Right? 😉
I had a moment of sanity recently when I dropped $325 on a 36GB SCSI drive and was greatly tempted to double it and get the 72GB version for $650. Then I remembered seeing all of the IDE drives in here and figured I that for the money I could get 10X the storage capacity if I'd relax my standards a bit and take a different approach.
See, a home file server can have almost exactly the opposite performance requirements of your typical server for a business workgroup. Instead of storing all data on a common server with high availability requirements, you can use a slower server box to offload infrequently-used data in a sort of near-line storage system. Since it will seldom have more than one simultaneous user, at 100Base-T speeds the bottleneck gets shifted from the hard drive to the network connection.
For my use, this would be the ideal place to dump multimedia files, which are commanding a huge and increasing percentage of my total storage capacity, but don't require much bandwidth for playback (at LAN speeds). Also, just having hundreds of gigabytes available online/nearline is so much more convenient that having them offline on removable media.
Welcome to the unwashed masses.
Thanks. Bathing can be such a chore.
Generally, the super high capacity drives (160GB and up) still command a premium due to the value of having that much capacity on a single spindle. I think the best deals currently are for the 120GB 7200 RPM drives which seem to be popping up with regularity between $80-$90 AR.
Good info, thanks.
No argument re performance but the degree of benefit just isn't there anymore unless you have unique application requirements(ie.,digital editing) or running a mission critical server where high availability and performance are paramount.
For the typical business applications, I would agree: I certainly don't push SCSI on my clients for their standard workstations.
But I can't agree on the degree of benefit--I have a pretty good A to B to B to B comparison going since I come home to SCSI after working with IDE drives during the day, and it's always a breath of fresh air--even coming off of working on the very latest systems---the hard drive is
the bottleneck on modern systems, and cutting that bottleneck in half to a fourth just makes everything more zippy.
I don't know about you, but I certainly don't intend to go back to a dialup internet connection any time soon.
Please overlook my initial sarcasm but you see, I am a recovering SCSI-aholic. I have known about every type of SCSI there is...SCSI narrow, LVD, Ultra SCSI, FW (I really liked fast and wide scuzzy girls...oops...wrong type of SCSI).
Heh. Perhaps this explains the paper bag over your head? Here's hoping I've done my part to nudge you back off the wagon.
In fact I am preparing to sell all my SCSI gear on Ebay with the exception of a single controller card for a high-end scanner that my wife uses.
Aww. But of that lot, how many boxes of 25-pin SCSI cables and adapters do YOU have?
Hopes this helps and gave you a chuckle. 😉
Indeed, on both counts. Thanks again, Mac!
zParticle
