those are exceptions, not the average cause of failure.. really worth mentioning any of that?
..how many master cylinder failures have u seen in contrast to caliper failures? the master cylinder is on the opposite end not contacting the rolling infurno when brakes applied. The seals and orifice at the top are smaller and robust. Don't often fail and when they do, usually its because of manufacture defect or untrained greasemonkey error. the internal ABS pump seals arn't going to leak externally or stop your brakes from functioning... they will however put a damper on your braking fun if bleed improperly.
Same as above. not worth mentioning, unless we're just tying to make people stop reading... I don't know about you but when i see a thread with a post as long as an autobiogrophy without anything readily usefull in the first paragraph, i just leave.
..fluid color may very from vehicle make/type, fluid color can indicate a problem, but not all the time. If you have excesive contamination or moisture in the lines, that is a broken system... you could keep flushing it, or you could get it fixed and not keep flushing it. Either way i was refering to non-broken systems in my original post.
I don't pretend to assume i know how far the fluid can circulate within reason on a closed manual hydrolic system like that. There are obvious circulation limitations if you've ever seen a system thats been compromized, contamination does not spread throught the entire system. I'm not refering to 'color', just because theres 'color' doesn't indicate compromise, theres many other reasons for color... And I'm not throwing out a bias opinion, my car is nearly 2 decades old and i rarely do brake work to it, but when i do the brake fluid comes out looking clean, I havn't checked the master cylinder in over ~3yrs now but last time I did it didn't change much in color either. I would not worry if it did though..within reason.
No that was for yours truely, you can ignore my posts i dont care.
