Clinkster
- Aug 5, 2009
- 937
- 0
- 76
No, the correct answer is
That would make the riddle cooler, but the solution the same.
if C was 0 it would still be wrong since there is a non-zero chance of getting the "right" answerNo, the correct answer is
It'd be better if C was 0%.
There would still be no correct answer, but there would be another troll choice instead of the 60% option which is useless, thus the joke would be better.
Get it?
Whooooosh.
Yea it's B)
Because normally it is a 25% chance, but since there are two 25% answers and one of them is the correct answer, it brings you down to 50% odds.
The questions premise is flawed. Therefore there is no meaningful answer.
They should have made C "75%"
Since there are two of the same choices, the answer is 50%. But since 50% is only one choice, the answer is 25%. But since 25% is two choices, the answer is 50%. But since 50% is only only a single choice, the answer is 25%. But since 25% is two choices, the answer is 50%. But since 50% is only only a single choice, the answer is 25%. But since 25% is two choices, the answer is 50%. But since 50% is only only a single choice, the answer is 25%. But since 25% is two choices, the answer is 50%. But since 50% is only only a single choice, the answer is 25%. But since 25% is two choices, the answer is 50%. But since 50% is only only a single choice, the answer is 25%. But since 25% is two choices, the answer is 50%. But since 50% is only only a single choice, the answer is 25%. But since 25% is two choices, the answer is 50%. But since 50% is only only a single choice, the answer is 25%. But since 25% is two choices, the answer is 50%. But since 50% is only only a single choice, the answer is 25%. But since 25% is two choices, the answer is 50%. But since 50% is only only a single choice, the answer is 25%. But since 25% is two choices, the answer is 50%. But since 50% is only only a single choice, the answer is 25%. But since 25% is two choices, the answer is 50%. But since 50% is only only a single choice, the answer is 25%. But since 25% is two choices, the answer is 50%. But since 50% is only only a single choice, the answer is 25%. But since 25% is two choices, the answer is 50%. But since 50% is only only a single choice, the answer is 25%. But since 25% is two choices, the answer is 50%. But since 50% is only only a single choice, the answer is 25%. But since 25% is two choices, the answer is 50%. But since 50% is only only a single choice, the answer is 25%. But since 25% is two choices, the answer is 50%. But since 50% is only only a single choice, the answer is 25%. But since 25% is two choices, the answer is 50%. But since 50% is only only a single choice, the answer is 25%. But since 25% is two choices, the answer is 50%. But since 50% is only only a single choice, the answer is 25%. But since 25% is two choices, the answer is 50%. But since 50% is only only a single choice, the answer is 25%. But since 25% is two choices, the answer is 50%. But since 50% is only only a single choice, the answer is 25%. But since 25% is two choices, the answer is 50%. But since 50% is only only a single choice, the answer is 25%. But since 25% is two choices, the answer is 50%. But since 50% is only only a single choice, the answer is 25%. But since 25% is two choices, the answer is 50%. But since 50% is only only a single choice, the answer is 25%. But since 25% is two choices, the answer is 50%. But since 50% is only only a single choice, the answer is 25%. But since 25% is two choices, the answer is 50%. But since 50% is only only a single choice, the answer is 25%.
FATAL ERROR STACK OVERFLOW
:whiste:LOL
Let's find where the OP lives and pee on his pillows
