angry hampster
Originally posted by: RGUN
Its definitely not a turbo designed for autocrossing in mind.
This what you had in mind? 😀
http://www.youtube.com/watch?v=OOP3_1TsXs4
lol, while I would love a vehicle like that (power/weight wise) I am doing my absolute best to turn the exterior styling into that of a family sedan. Im looking into scoop deletes or revese scoops and a new trunk.
Originally posted by: DivideBYZero
I guessing Evo, but who enjoys guessing? :|
Zerocool is infact correct. It is my 2007 STI -- please begin telling me how I dont know what Im doing and it will explode.
Nothing like making 240 HP/L
you don't know what you're doing and it will explode 😉
Scoop delete should be easy as you'll be using an FMIC rather than the stock top mount.
And then you'll be killed. 😛
Originally posted by: bananapeel42
Is that 600 rwhp? what kind of rwtq? Or are you rating at the "flywheel."
LS2's and LS3's with a bolt on supercharger and no real supporting mods other than intake / exhaust make mid to high 500's to the wheels. That's not bad but still doesn't get you to 600 rwhp.
However, their power under the curve will be a world of difference than that 600 peak hp from the WRX.
Also, V8's are easy to get to 600HP. My cobra is a 480 rwhp / 500 rwtq to the wheels and that only took about 1400 dollars.
What he has done probably took 10,000 dollars, and I already have a built engine stock.
Originally posted by: nkgreen
Yeah, I'm curious to see what your budget was. 😛
Jeese. If you already had a Vette why didn't you just slap a low boost 7-8 psi supercharger on it?
It's not like fuel would be a big issue, changing the injectors is cheap and easy. That should still out run the STI in the 1/4.
Not saying STI's can't be very fast cars as I recently had one outrun me to 100mph, as street tires and 500 rwtq don't mix.
What kind of mustang 4.6L? All I have is a 4.6L too, but it's 4 valves per cylinder and has forged internals.
Umm. Well, a blown LS3 vette I've seen run 10.4 at 136 with a 7 psi supercharger on stock engine.
No suspension mods, intake and full exhaust. He had quite a bit of room left it seemed.
There is no way on earth I see a 450 rwhp STI trapping 130+, power to weight just doen't make sense.
I don't know the import world at all though. What does the car weigh?
What kind of torque do you get down low? I make 470 at 2600 rpm.
