Well I took ATOTs advice -- teaser inside
RGUN
1,007
I pick up my car next friday -- it is expected to develop 600hp
For the time being, this is my daily driver
Arkaign
20,736
1,379
STI, Evo, Vette, GTO? I hope it's one of the latter for reliability's sake :)
RGUN
1,007
Going to try to stick with the stock bottom end for the time being :p Once I add methanol/water injection I will have to go to a fully built block. Unfortunately Ill get the car back with more power left in it, but any more boost will just tear up the unsleeved block and cast components (and the notoriously weak bearings)
RGUN
1,007
Originally posted by: DivideBYZero
I guessing Evo, but who enjoys guessing? :|
Zerocool is infact correct. It is my 2007 STI -- please begin telling me how I dont know what Im doing and it will explode.
Nothing like making 240 HP/L
DivideBYZero
24,117
Meh, you're not going to get that from me. However, 600hp is at the VERY top end for those motors. I'm sure you'll be employing the services of a specialist company to do the work, so all the best!
Fenixgoon
33,282
12,847
you don't know what you're doing and it will explode ;)
ayabe
7,449
Should be ok, hope you have a nice set of gauges.
It's not just the motor I would be worrying about your tranny as well, I would go PPG from the get go, IIRC the stock STI tranny is only really rated for 450lbs TQ.
Also your rear half axles, I would take a look at the Perrin subframe lockdown kit for the rear end just to tighten things up a bit.
Should be awesome though, congrats man, that thing is gonna be sick.
Arkaign
20,736
1,379
Jesus. That doesn't sound like a reliable setup, but I bet it will be hideously fun. I'd much rather have an LS2 that will do 600hp without even breathing hard. Of course, LS2 isn't commonly found in AWD clothing, so :p
RGUN
1,007
The STI 6spd tranny is well known for being pretty much bullet proof. The two fastest Subarus in Canada (street legal) are both running an '07 STI 6spd (07 will allow a trap speed of 130mph before shifting out of 4th). For instance we have a wrx wagon with a full DSS stage 5 setup and slicks on all 4 running in the 10's with a stock 6spd tranny, he has well over 600hp.
I have a set of Defi gauges that Im not happy about having paid for -- they are so damn expensive, but they match stock perfectly and I couldnt be happier with them.
The real axles are definitely a weak link, I would rather not put in the subframe kit, I want that little bit of movement to cushion any severe launches. I have been looking at the DSS rear axle kit.
Got a new motor and heads priced out today too! Then I can run this setup to its full potential!
RGUN
1,007
Originally posted by: Snakexor
beware of piston 4....have you overhauled the engine?
Engine internals are bone stock cast crap and stock bearings. We are taking precautions and not running it at full boost or with meth (or race fuel). The EGT probe is an inch outside of the head under cylinder 4 :p We are going to be careful not to exceed 1650deg. F on that one, but with the upgraded fuel rails cylinder 4 is no longer the last one to get fuel, so it isnt as much a problem as it was with the stock fuel system.
RGUN
1,007
Well I hope you are wrong :p Just FYI, I wouldnt say that american V8s can do 600hp without breathing hard, I wouldnt want to run one that ragged without opening it up. Besides, where are you going to find a brand new stock short block for $1750 for those V8s
RGUN
1,007
Damnit why didnt you tell me this last week -- you could have saved me a serious amount of money....
:p
RGUN
1,007
Dare I say its one of the best Subaru builders/tuners near within 5 hours of the border.
Arkaign
20,736
1,379
Well, I guess what I meant is that I've known plenty of people with modded 5.7s and 6.0s that push well north of 500hp without any reliability issues in the motor itself.
Still, if you don't push it real hard constantly I bet it will hold up decently.
RGUN
1,007
Well the most important part of the longevity of any highly strung engine is the tune. I have absolute faith in my tuner, and we are keeping the EGTs low and the cylinder pressure in line with what a stock block can hold.
halik
25,696
That won't be fun to drive IMO, big turbo like will lag like no other south of 4500rpm. My brother had a 450hp eclipse with some hybrid turbo and 26psi
RGUN
1,007
Its definitely not a turbo designed for autocrossing in mind. The lag wont be quite as bad as that, and a set of equal length headers will also help to bring that down. If I had more money I would go twin scroll headers/uppipe and get the spool right down.
While full spool will certainly occur later than stock, you have to understand that while the stock turbo could spool to 20psi by 3500rpm, the new turbo, which might be able to spool to 10psi by then will probably still make more power. So while you are correct, that I could have selected a turbo to better make power down low, this one certainly still increases the power throughout the entire rpm range, but biases its major power improvement to the 4000rpm+ range.
alkemyst
83,769
19
while the LSx engines are great bang for buck they are really over talked about lately...same with turbo lag...
I am debating an LSx swap vs SR20DET vs just buying a GTO right now.
There is a mofobucs video on youtube showing many very fast cars...there is SR20DET 240SX that just wipes them all.
its running a GT35R and built engine.
I am looking at running the GT2871R.
DivideBYZero
24,117
I want to see the final result! I still pine for my old scooby at times...
