Hi all,
I need some advice in order to determine my next move with this situation.
I recently obtained a USB game controller (dance pad, specifically) that is supposed to work without drivers. I want to hook the controller a computer running Windows 2000 but it does not recognize the function of the peripheral. It only registers as "USB Device" with incorrect drivers. On this same computer, other USB products work fine. Both a USB Wingman gamepad (drivers are installed here) and a USB DVD drive (plug and play) work absolutely fine, but this dance pad is unrecognized and unusable.
On another computer running Windows 2000, the dance pad is recognized and works immediately. Why is it that this one computer will not recognize the device? If the USB hub is the problem, I can just swap one in, but if it's something OS related, I'm afraid I might be out of luck here. Any suggestions? Thanks so much for your help.
