I have a P4 2.4 ghz system (not overclocked), and have a weird problem. My idle temps were 25/35, with one exhaust fan. I decided to add an intake fan to try and bring things down a couple of degrees. The problem is that my lame case doesn't have fan mount on the front; it has one on the bottom. So I put the fan on the bottom and made some two inch risers to give it some intake room. Now my idle temps are 27/37. It seems to peak a lower (ut2k3 used to peak the cpu at about 49, now about 45), but it doesn't seem right that the idle temps should go up. Any ideas?
System
Asus P4PE
P4 2.4
Maxtor 80 GB HD w/ 8 MB cache
512 MB Crucial PC2100 RAM
BFG ti4200 w/ 128 MB RAM
System
Asus P4PE
P4 2.4
