Ive run into a small problem transferring files from one PC to another (peer to peer network)
PC A:
dual boot: Win Me, ie6, Norton 2001, current updates/2k Adv Server sp2, ie6, Norton Corp Ed, current updates
800mhz, 256mb ram, Linksys 10/100 card
PC B:
dual boot: Win 98, ie6, Norton 2000, current updates/Win NT workstation, sp6a, ie6, Norton v5.02.06, current updates
233mhz, 128mb ram, 3com 3c905tx 10/100
Linksys 10/100 5 port switch
Everything is working fine until last Thursday, I was in 2k server and an email came in with the sircam virus, Norton Corp picked it up and quarantined it, I then deleted it and continued on, updated the virus sigs on Friday, then again every day after that to make sure. I did get another 2 emails with the Nimba virus but both were picked up by Norton
Now I download the norton virus update on PC A and when i try to move the virus update from PC A to PC B, I get a dialog box that says 10 sec to go (files only 2mb) then it disconnects saying the network resource isnt available anymore..but Im looking right at the folder of PC A on PC B, I tried with other files and it does the same thing, going PC B to PC A gives the same thing.
I tried (from PC B) to map the server folder (PC A) (\\server800\e$) and also tried it from start\run with the same result.
Im logged onto each PC with the same ID and PW, Ive run the virus scan and it has not found any virus', also ran the Nimba removal tool from Symantec just to verify no Nima's are on the PC, none found.
Ive booted in Win ME and tried to do the same thing, no luck, tried booting into win98, also no luck
I can see the PC's in Network Neighborhood, am sharing files on each PC, each PC is set to DHCP, also tried setting an IP, with no luck.
Ive run out of ideas other than rebuilding both PC's, anyone got an idea? THanks!!
PC A:
PC B:
