windows 98se, fresh install
here are the symptoms - whenever a phone is plugged into the modem, for some reason, the modem "picks up" the phone, even when the computer is off. no other phone in the house works when the phone cord is into the modem, it is like a phone is off the hook. when you connect a phone to the other plug on the modem, there is no dial tone. when you try dial out on the modem through windows, it gives you a "no dial tone" error. when this happened originally, i tried different drivers. but it still does this, then i went ahead and pulled that modem and installed a new one, windows saw it, asked for the drivers from the cd and installed it, but, same problem. when you look at the modem under device drivers, it shows that it is okay and working correctly. 🙁
any ideas???
any ideas???
