imported_waldo
So I am building my first system....and I have the DVD drive set as master(perhaps I should set it as slave) but when I disconnect the ide cable, I get the drive to open, which shows that it isnt' teh psu, tehn I plug the ide cable in, and I get no response from teh drive...it is installed correctly..do you reckon it should be set to slave?
I am booting off of a SATA Raptor primary, have a Seagete IDE as secondary, and the dvd seperate....all have their own cables, cause they just aren't long enough to connect the Seagate and teh dvd to teh same cable, but they are both secondaries to the SATA. Should the seagate be put as a master drive and the DVD as a slave? Any thoughts?
The mobo isn't recognizing the DVD or the seagate, but is recognizing the WD!
Cheers
Jeff
P.S> the mobo is an ASUS PC-DL
Cheers
Jeff
