Most likely it is a fuel problem, but check first that the exhaust port is clear.
Sometimes there is a fuel filter employed & to access it requires removal of the tank.
The carburetors typically employ a flexible diaphragm that becomes stiff or disintegrates with age so the carb doesnt work well. As such, do not attempt to clean the carb with anything other than gasoline as cleaners/solvents (particularly carburetor cleaners) can damage the diaphragm. If you must use a cleaner, then use Berrymans B-12 cleaner.
Pulling and cleaning the carb, replacing the diaphragm, filter (if any) and any other soft parts is the correct solution, but from my experience, it is time consuming, a dirty job and still may not result in a 100% solution. Dont be surprised if you have to pull it all down & reassemble it over a few times before it can be made to work well.
