web based IRC
sciencewhiz
5,886
8
Is there a way that I can access the #teamanandtech channel using a web based client? You used to be able to do it when we were on othernet, but I can't seem to find a way to do it now that we are on worldirc. I'm at school and installing mIRC isn't an option.
ViRGE
Elite Member, Moderator Emeritus
167
Unfortunately, no. WorldIRC offers a "web based" client, but it only lets you into #help as far as I can tell.:| They said they're going to get the Java client back up soon though.
strates
509
Actually, the folks at mIRC have been kind enough to put up a java client which can be used to connect to any server. this page can be found at www.mircx.com
strates
MWalkden
1,082
Just tried it and it works but requires a plug-in so you still need rights to use it on a PC more than likely. Give it a whirl and see it it does the job.
.MW
sciencewhiz
5,886
8
Thanks Guys! :D
I won't have a chance to try it at school until next week, but hopefully it will work.
sciencewhiz
5,886
8
Ignore the last message. I just got a chance to try it, and it worked. It is to slow to use on whatever POS computers these are. (Probably original pentiums). Just in case anyone else has my problem, mircx does work.
Jani
405
OK. Here comes little advertisement :) You can now join #teamanandtech without any fancy programs.
All you need is a Java enabled browser like Netscape 4.0 or Internet Explorer 4.0 or above
Just use address http://guru.rdx.net/irc/
Jani
405
Please comment if this web based IRC client is useful.
Just fill your nick & press "connect now!" button and *zap* *kaboom* you're in #teamanandtech.
Too much Batman today :frown:
sciencewhiz
5,886
8
Jani,
That looks like the same window that mircx statrs, which means that on the computers at school, it will run to slow. When I tried it last night, I would 6-8 lines of text all at the same time, even though only 2 or three people were talking. I guess Java clients aren't made for pentium classic systems. :(
Edit: It works fine on my PIII system here at home on a 56k connection, but not at school an a pentium with a super-fast connection.
