Weak laser when burning....HELP!
LemonHead
1,041
Anyone ever have a burner that had this problem? The burn seems to go fine, but it takes a while to "close the session", and when I look at the CD it seems that the burn is not very "deep" or "even" on the CD. When trying to read the disk, it takes my CD ROM a long time to read the disk and sometimes it will not read it at all.
I'm realizing that maybe the laser is dying on this thing. Anything I can do?? It's only about 2 and a half years old and I know it is slow (4 x 2 x 24) but money is tight and I don't know if I have any options other than tossing this piece of s#it in the trash. (ARRGH!!)
I will probably have to get a new one, but just wanted some input and or thoughs from anyone.
Thanks.
BTW, the burner is a Creative 4224E 4x2x24
bozo1
6,364
Are you using 700MB disks? Some burners, especially older ones, have problems with those.
LemonHead
1,041
I've used both and the result is the same.
