Having a problem with my WDBHG70000NBK playing files from my NAS. It will pause and buffer, then play in fast forward until it catches up to where it should have been, every three-five minutes. I have never had this problem playing files from the USB slot (it can even be the same exact file).
Both the WDTV and NAS are hooked up through CAT 5e to my router. I can play files on my iMac just fine with the same connection as the WDTV. These are full BR Rips from MakeMKV with the lossless audio track (DTS HD/True HD).
What could be causing this issue? Files play fine from a flash drive, files play fine with above setup on my iMac, but they wont play properly on the WDTV
Any help would be appreciated.
