WD Easy Store Shuck Help
yippykayyay
Hello,
I bought a WD external hard drive to shuck and even after taping the 3rd pin on the hard drive and using a molex to sata connector the hard drive wont show even in BIOS. Help?
VirtualLarry
56,587
10,227
DId you accidentally tape over the 3rd pin on the data cable, rather than the power cable connector?
Otherwise, seems like the drive might be DOA?
