Way to turn on PC without case?
Coldkilla
3,944
Is there a way to turn on the PC without a case?
I have a "GIGABYTE GA-965P-DS3 LGA 775 Intel P965 Express ATX Intel Motherboard"
Any ideas?
mechBgon
Oct 31, 1999
30,699
Use a metal object to make a momentary electrical connection across the motherboard's power-button pins where you'd ordinarily plug in the case's power-button wire.
Kakumba
610
Screwdriver or knife, make connection between pins as mechBgon suggested. Its safer than you might think, as long as you don't spear your mobo..
Blain
A battery?
Are you asking about operating a MB even without a power supply?
rudder
19,441
86
I normally just use a little piece of wire. Strip the ends just enough to have some metal showing. No chance of spearing your mobo!
rudder
19,441
86
Originally posted by: ultra99
can we use a jumber from an old hdd?
If you can find on that fits. But its not going to be a constant connection. You just bridge the pins momentarily and the pc powers up. Bridge them for a few seconds again and it will power down.
