I have wavy lines down my Radeon 8500.
Looks to be interference, but I have ruled that out.
I have it connected to the DVI-VGA adapter, only because when I connect it to the VGA output, I cannot make it the primary display.
I also have a Radeon 7200 PCI installed, and that powers a 17" monitor. It's output is fine.
The 8500 just replaced a 7500AIW, and it did not have these "wavy lines" when I used that DVI-VGA output
I am using the 7200 as well because I want to enable both monitors, and be able to actually display diff things on each.
With both monitors connected to the 8500 (without the 7200 installed), I only get the same image on each. That is not what I want.
I am using the latest Catalyst 2.1 from ATIs site.
Any ideas peeps?
Thanks,
Edblor
Any ideas peeps?
Thanks,
Edblor
