Water Pumps/Tubing
actually it shows the swiftech beating the thermochill, but not by much.
The beauty however about 120.3 radiators is they have a much higher impact at higher speed.
Marci didnt post differentials at higher RPM fans. At 1800+ RPM's on deltas, the gap gets bigger from the pa120.2 vs 120.3
How do i know? i have both 😀 My 120.3 blackice GTS will outperform my thermochill. If it didnt, i would of gotten another PA120.2 for my NAS! 😀
Anyhow, its a completely different story if you step up to a PA120.3 <--- too bad there almost always sold out, or every time i have cash to pick one up, ITS SOLD OUT!
😛 like ive been telling tons of people, i dare you to try to stress one without using TEC blocks.
you gotta be kidding me..the difference was close to 0 or like a t0.1-0.2 of degrees...this is a comparison of a PA120.2 VS MCR 120.3 rad....that is amazing..you can use less fans at lower speed for same performance...lower noise
Sure the gap may increase a bit with 3 120mm@1800 rpm...but so does the noise
Now with all this debating..the fact is the thermochill is alot more $$$ for a smaller rad too...cost is an issue...but the best is expensive
But if you need a 120.2 for space that is as good or better than most 120.3 rad...get PA120.2(now the data is not brand new some newer rad may perform better too)
