After attaching Fan Mate 2 controllers to my dual 80mm intake fans, I've discovered that my next loudest component is the water pump... but no way to quiet that part w/o replacing it.
Anyone have experience with reliable pumps that are also quiet?
also i missed up on the pump order i mistaked the mcp650 for another pump. iconfused the mcp650 with the mcp600
new order is
mcp650 (d4) > mcp655 (D5)>aquaXtreme 50z (mcp600) > mcp350(DDC) -noise
mcp655 >mcp650 > mcp600 > aquaxtreme 50z > mcp350 - flow
