Originally posted by: Roger
I was wondering the same thing. I suppose that's true, but I don't think it's the main reason they use aluminum..... they use aluminum because it's light weight and cheap, lol... i'm sure the added heat transfer is just a bonus.
I'm kinda having a hard time picturing this, though. I don't really understand how better or worse heat transfer is going to effect the flame front speed...
Just because the temperature in the combustion chamber is higher, so the air/fuel charge is heated up more before it's ignited?
Cast iron is cheaper than aluminum
Listen carefully, the thermodynamic properties of a
compressed air/fuel charge is directly affected by the surrounding temperature, notice that a cold engine requires a much richer mixture to fire, while a warm engine requires a leaner mixture (Stoichiometric, 14.7 to 1), this is because
fuel atomization is morte easily produced with the excitation of the fuel atoms (heat).
Picture the air/fuel charge not as one unit, but many thousands of gas droplets mixed in a small compressed atmosphere of oxygen/nitrogen, when the spark plug fires, the first micro fuel droplet ignites causing it's neighbor droplets to ignite and so on and so on, this is the
flame front, now when temps rise in the combustion chamber, the fuel atoms are really jumping around, this causes the fuel to burn more rapidly, the flame front now spreads across the combustion chamber much quicker, ofcourse this is an over simplification of the events
You must also understand that as the combustion chamber grows hotter, the fuel atomization increases because the micro droplets are more easily broken up as the temperatures rise, as the drops get smaller, the fuel burns more readily causing yet another increase in flame front speed.
Got that ?
Good, now ever notice that an overheated engine pings ? (Detonation)
Apply what I just stated, as temps go up, the fuel becomes easier to burn, once it reaches the flash point it will self ignite with an
extremely fast flame front causing an
explosion inside the combustion chamber, this explosion rings the metal parts inside the engine causing the peculiar "ping" sound, this also happens when cheap gas is used because the
resistance to ignition of the cheaper fuels have a direct relationship with flame front speed (low octane fuel burns much more rapidly than high octane fuel).
