Originally posted by: Zebo
Mediocre? That heater core you're using has a larger surface area than any after market designed watercooling radiator. You are using two very large throw 38mm wide fans. I would not call that mediocre dispite your savvy economy shopping... Don't let price fool you your system disipates heat better than any swiftech kit.
And what did you get for that? 10C compared to an you older XP120, don't you think a Big typhoon would close that gap?
I estimated 5C because that's what I got from the air move using a
swiftech 2x120mm kit and I have GPU in the loop. So for me, from a temperture standpoint, it was not worth it. It's also a PITA to change any hardware. Have to bleed system - hopefully don't spill and reassemble and fill back up. Just to change a processor is like an hour long process. It's expensive - my kit's about $300 compared to good GPU and CPU aftermarket HSFs of about $90 total. Three times as much for water... all for 5-10C? I don't think so.
However, it's silent, which air can't be i've tried, which makes it worthwhile to me..
I think it's important we water coolers make aware the dangers and costs and not try and hide anything just because we do it. That does'nt nessesarly make it right for everyone.
