Originally posted by: WarmAndSCSI
I don't think it'll be. I just can't see Dell putting water cooling systems into their home PCs... just too risky.
Why is it too risky? leaks that can cause shorts? If there's a tech that can give greater clock speeds a company will find a way to make it commonplace and market it. Watercooling = greater overclocking potential =also= greater clock speeds in the end.
Yes, I can see overclocking becoming mainstream.
Yes, I can see watercooling becoming the cooling of choice: quieter, smaller, needs less air space, more cooling potential.
Yes, I can see boosting clock potential through watercooling (there was an article a while ago that scientifically prooved that lower temps = higher speeds (through higher core voltage tolerances) = higher GHz (remember the article from a few months ago about the 5GHz off the shelf computer?)
Like I said, it wouldn't take terribly much R&D to make a reliable water cooling system. The "technology" existed 40 years ago. They could even make it a closed loop system where you would never have to add water.. I really don't think it's much of a stretch.Originally posted by: WarmAndSCSI
Perhaps.. It wouldn't be much worse than a system who has never seen its case off, and has dust bunnies the size of Texas, causing it to overheat and crash, though.Originally posted by: WarmAndSCSI
It might happen in a year or two. It'll take PC manufacturers a while to adapt. I can see it being implemented in high-end systems before home PCs. It'd add another level of failure in home PCs.
bah, I think the whole leaking thing is blown way out of proportion.Originally posted by: Schadenfroh
i could hear the tech calls now.
Tech rep: "yes? how can i help?"
Customer: "my pc aint workin"
Tech rep: "could you give me the details"
Customer: "its shocking me"
Tech Rep: "why is it shocking you"
Customer: "cause there is a clear non alcaholic substance seeping out of the case"
It wouldn't be terribly hard to make a watercooling setup that was virtually impossible to leak, except maybe a physical defect or puncturing it with a screwdriver or something.
Besides, you would never be shocked by the 12v max a system power supply puts out, the water would never be able to leak into the power supply.
BTW.. alcohol. 😛
Having electronics submerged in oil is nothing new. Deep water submersibles do this to prevent pressure differences.Originally posted by: ThaGrandCow
BTW.. alcohol. 😛
How bout a liquid that doesn't evaporate?
Like a non-electrical-conductive heat conducting liquid...
<cough>mineral oil<cough>
See my post above about bleeding edge computer geeks making new stuff in their garage <insert slashdot story about guy who overclocks 300% when dunking MB + CPU in bucket of mineral oil here>
EDIT: Before anyone says otherwise... yes, it was a real story and did actually happen.
