Water Cooling Setup
Originally posted by: thehstrybean
Yep..I emailed FrozenCPU to see if they knew anything...
You're the second person I know of who got a bad rad from FCPU. Use this as a chance to get a refund and a 120mm rad, if you have a place to put it that is.
Well, sorry to kick a dying horse, I mean thread, but frozencpu finally refunded my radiator...(They lost the package, but I called them and told them the tracking number, and I got it today...)..It worked (WORKED is the keyword) great...No leaks, great cooling...The screw holes that the fan connects to were too small for the screw that go with my fan/filter, so I was going to make the hole diameter bigger...Well, I went a little too far and punctured it...No it leaks, just like my last one...Luckily, I ordered another from cheapgoose here...It works too...Three questions: 1) Will fronzencpu replace the rad AGAIN if I was trying to make the holes bigger? 2) If not, is there any way to fix this? 3) YES!!! I remebered it!! The rad I bought is spray painted silver...Will the paint hurt its conductivity of heat?
