thehstrybean
After my failed Poseidon liquid cooler, I decided to build my own system for my Antec Aria...I ordered (and today recieved) a Danger Den Athlon 64 TDX 3/8" water block, Swiftech 80mm Radiator, fan filter, and tomorrow I should get my Danger Den DDC-12V Pump, Fillport, and elbow connectors....Since my case is so small, I'm wondering how to lay all of this out...1) How should I run the tubing? (I'm thinkin pump to cpu to radiator to pump, with the "T" port run into the pump...A guide I found on the 'net said it should go another way...How should I run the hoses?) 2) Is it ok if the radiator is on it's side (so the in/out's are on their sides?) Thanks much!!
