Originally posted by: HardWarrior
Swapping fans really isn't that easy. Even if it was, why should a person that's new to water-cooling be left with trial and error? If those of us who've been using water for an extended period are good for anything in places like this it should be as a resourse that helps new people not to have to reinvent the wheel.
I do agree with you hardwarrior, but there's no one solution being offered as the best option. I would put myself through the hassle of swapping fans till I found the best results, and I wouldn't consider that to be much of a hassle, seeing as how I'm looking for the best way to cool a system that has a ton of my time and money tied up in it already.
Then, I could recommend a configuration to someone based on my system specs. Unfortunately, my solution would differ from someone elses with an equal amount of experience, and the op would be left to find the best solution through trial and error.
I say this having absolutely zero water cooling experience; I rarely take advice as the gospel.
