Originally posted by: mindwreck
For about 90 used could get some good used stuff on the FS/FT and build a very good watercooling system. I built mine for about 100 cause i bought a new pump and waterblock. For the radiator i got a used heatercore off FS/FT.
Originally posted by: NINaudio
Hey, Mrvile hit on most of the facts. He's especially spot on about the air for a college pc. If you don't have everything secured in a watercooled one it can be a mess, not to mention it can add a bit of weight.
You can however, make a watercooled pc quiet. Some pumps can make a lot of noise, but some, like the one I have are particularly quiet. I can't even hear it running at all, I have to feel it to be able to tell it's on. Less fans usually means less noise as well. Granted, some high power 120 mm fans can be loud, but I've found that a loud 120 is not as bothersome as a loud 80 mm fan.
There are also things you can use besides water. Fluid XP is an alternative and it is non-conductive, so if it leaks you won't be killing all your equipment.
When I was looking at water, I actually looked at it as an investment. Next time I change mobo's or a graphics card, I may just need to buy a new watercooling block, but I will already have everything else. $50 is about what you'd pay for a good waterblock or a good high-end air cooler. And there was nothing else out there that would get my video card to be running at 50 degrees loaded!
Originally posted by: Bona Fide
I'm pretty sure a Zalman or Thermalright HSF will work just as well as water cooling.
I have to disagree with that statement. I was under the same impression until I built an inexpensive H20 kit. Here's a mini-review I did to show the difference between H20 and a Thermalright XP-120.
Originally posted by: Mrvile
Well, you use one of those smaller, Mag pumps that are definately more quiet but have about half the power as a Laing pump. For CPU cooling alone, a Mag pump is fine, but if you want to add video and/or NB cooling, you'll probably want a more powerful pump.
I have to disagree with you here. [Kindly of course] 🙂 The swiftech mcp 350 and danger den ddc 12v (they're really the same pump, just rebadged) are very small, quite quiet, and have a high head pressure. That high head pressure allows them to run several blocks without losing much in the amount of water actually moved.
